Wix 51372 cut open 2k miles
USA - WA
Wix 51372 cut open Ford 4.6 2000 miles. Miles SB 10w30 was used. Had to change the starter motor and I hate jacking the car up so I just changed it while it was in the air. Filter looked great, was on for 9 months and there were a lot of cold starts on this OCI. Replaced with same filter.
Yeah looks good. I run the 57899 and I think it’s basically the same filter but with a lower bypass setting. Thanks for the c&p.
It looks excellent. Even though it uses a dome bypass, I'm going to call it an OG Wix with coil compression spring. Some Wix/Napa Gold applications have (for whatever reason) always used dome bypass. Ford applications like topic 820S equivalent is one such example.
Thanks for c&p.
Wix 51372 cut open Ford 4.6 2000 miles. Miles SB 10w30 was used. Had to change the starter motor and I hate jacking the car up so I just changed it while it was in the air. Filter looked great, was on for 9 months and there were a lot of cold starts on this OCI. Replaced with same filter. View attachment 80794View attachment 80795View attachment 80796
Looks real good. Did you put more Miles blend in?
Thank Yiu for great photos and post 🍻👍
Thanks for c&p.
I wish I could find a filter of this quality, in this size, with the threaded end bypass. I’m not talking about a combo valve either.
