The bypass setting for that one is 8-11psi, versus 11-14psi for the Wix 51358.57356XP
They are both within the Nissan spec for PSI. As long as it can physically fit, either short/long filter can be used.The bypass setting for that one is 8-11psi, versus 11-14psi for the Wix 51358.
If there is diameter room, then look at the 51334xp filter
If there is diameter room, then look at the 51334xp filter.
Compared to what ?The XP filter is going to be the more efficient filter and is their top of the line model
The XP isn't as efficient as the regular WIX filter. Where you getting your efficiency info ?Compared to their regular, non-synthetic oil filters and arguably compared to all other brands of oil filters out there.
It's hard to beat Wix and their oil slick trixx View attachment 49569
