I wanted to replace this and cut it open mainly out of curiosity but also to insure my coolant flow to the filter was correct.
Yeah, pretty clean, as expected, but boy was the difference obvious when you looked at the coolant in the over flow tank. I wish I had taken a Before photo to show it, but after the 1500 miles it looked like brand new coolant.
I replaced it with a Fleetguard WF2107 which is listed as the correct crossover (with no SCAs) as I got a much better price on them than the Wix.
However its important to note it has no internal restrictor like the Wix and Baldwin does. My filter head has a restrictor built into it, so I had no qualms about using it, but, it could be an issue if yours doesn't.
I also prefilled the filter with RMI25. Last time I tried to use RMI, I poured it in the overflow, which is where it sat pretty much the entire time. It never mixed into the coolant. Not enough mixing going on in there I guess.
I thought I might try dosing it into the filter and that worked spectacularly. Its now throughly mixed in.
Bonus pic
This is an example of the trash I get out of the cooling system everytime I drain it. This is leftover from the last time I drained the coolant on it.
Bonus pic
