Good day All
As most of you know, I'm currently building a Factory Five Roadster. The link is here ->https://bobistheoilguy.com/forums/threads/project-cobra.391098/
Anyway, I'm looking for some input on the wiring for my car. The kit I purchased came with an aftermarket wire harness, and I think it will work out fine. As noted in my build thread, I have installed the fuse panel and started to route the main harness. I have routed the front harness for the head lights, turn signals and fan wire. One thing I noticed is this wiring kit does not include a ground wire for the front harness. Instead, it has separate wires in the kit that appear to be for individual grounds for each light. I have thought about this, and I am not a fan of separate grounds for the lights. My theory is too many grounds will end up being a problem at some point.
So now my question, does anyone see an issue if I run a wire in the harness that is a ground and then ground it near the fuse panel in the foot box? I would run a common wire in the harness with branches off for each of the lights. I would solder and shrink wrap the connections. I would also do the same thing for the rear harness when the time comes and tie the grounds together into one connection in the footbox area.
Thanks in advance, for any help that is provided
