- Joined
- Nov 29, 2009
- Messages
- 7,438
So what causes this to happen after about 600 hours? Maybe the last 25 hours it wouldn't want to restart when hot. You guys told me that was excessive valve lash and I believe it now. The valve lash was about 4 times larger than what it should have been. Will that cause a camshaft to fail? I'm just assuming it's one cam lobe wiped out because the exhaust valve still opens and closes normally. I'm not sure if they use plastic gears and lobes or not like on the old flathead briggs. This is a newer ohv briggs. I haven't taken it apart yet, but I'm guessing one probably broke off.
