Most blunders happen with 4x4/AWD, especially if they are Subaru or JEEP.You mean we all don't need some sort of 4x4/AWD to not have a "blunder"?
Numerous European countries have similar laws. It is also cultural thing. Even before these laws becoming specific, it was tradition that you have two sets of tires.Snow tires are not new to BMW's. Here is something from Bavaria. Enjoy.
www.bavariannews.com/blog/2019/09/21/everything-you-need-to-know-about-winter-tires-in-germany/#:~:text=According%20to%20the%20USAG%20Bavaria,4%20millimeters%2C%20according%20to%20ADAC.
And... they advocate for snow chains also, on top the mandated winter tires, as conditions require. Maybe they know something about snow chains that North Americans don't.Snow tires are not new to BMW's. Here is something from Bavaria. Enjoy.
I disagree. I've explained multiple times why 4WD vehicles stop better than 2WD in poor traction (assuming same tires). The same applies to steering, but to a lesser extent. I have explained the physics multiple times here, no one has contradicted me, and yet the myth continues to be repeated.
Yes, it is easy for a novice driver to overdrive a 4WD vehicle with A/S tires. But that does not change the laws of physics.
Technically correct. About the only advantage of AWD vs regular is that those cars weight more. More weight, better traction on the same footprint. Although more weight usually translates to longer stopping distances. But if traction isn't optimal, it's possible to get better traction and shorter stopping distances. Would have to run some tests to see if that plays out as expected.I'd like to see your explanation why you feel 4WD stops better in snow/ice.
I've seen a lot of videos from professional studies of winter tires vs all season and 2wd vs AWD. All of them show the same thing. The only thing that improves stopping power is better traction , that is tires or chains. AWD does nothing for reducing stopping distance. I haven't seen anything that compares 2WD vs 4WD in winter conditions.
Exactly what I was asking. With ABS, wouldn't that negate the factor that is claimed in this video?No ABS?
Krzyś
I think you have it the other way around. In most conditions, ABS leads to shorter stopping distances as it's the coefficient of static friction vs kinetic friction. Static friction leads to shorter stopping distances. The snow plow effect on a locked wheel is one of the rare instances where you get shorter stopping distances.I remember reading in the mid 80s, I think it was, Audi that stating in the deep snow cars stopped better with ABS off. Built a wedge of snow under the tires. I believe in a lot of conditions ABS means longer braking distances, but allows straight line braking and the ability to turn and maintain control.
Their advice was not to exceed 50 km/ hr when using chains. That’s 30 mph. Not for me, thanks.And... they advocate for snow chains also, on top the mandated winter tires, as conditions require. Maybe they know something about snow chains that North Americans don't.
Ie.... If you have a good set of winter tires, you don't need snow chains.
Technically wrong.About the only advantage of AWD vs regular is that those cars weight more. More weight, better traction on the same footprint.
So you drive more than 30 mph in the snow and ice?Their advice was not to exceed 50 km/ hr when using chains. That’s 30 mph. Not for me, thanks.
You realize you’re talking to a Canadian.So you drive more than 30 mph in the snow and ice?
You drive faster in the snow and ice so you can get to Tim Horton's faster?You’re realize you’re talking to a Canadian.
