- Joined
- Sep 23, 2017
- Messages
- 429
hello guys! i just picked up a 22 range rover sport, it came with 275 40 r22 all seasons but here in alberta canada they dont really seem to cut it. i want to get a dedicated set of winters. sorry i am a bit of a noob but i heard its recommended to get a less wide tire for winter which i believe is the first number on the tires. i did some research and tried to look at some winter tire packages etc, i will go with aftermarket tbh becaause i only want to spend around 2000 with new winter tires. so here is where i am so far,
it seems like i can run 255/55 R20 or 235/65 R19 but i believe there are other sizes that i can also run, with my brief reseaarch it seems liek i can find way more tire options and rim options for a good price in this r20 size compared to the r19 so i am already leaning to the r20. however i wanted to confirm, are there other tire sizes that will fit our trucks without rubbing? i am going to be buying new rims and tires so it doesnt really matter.
when i played around with some configs at a website called pmctire, i can get either set of around $2000 cad.
lastly, i am not an expert with rims or anything, i notice that our trucks are a 5 x 120 but then i get confused with offset and the centre bore size, do those have to be exact? i believe range rover is 72.6 but then sometimes im seeing other aftermarket wheels having a diff centre bore
if i could get a run down on what combo will give me the best pricing and also some rim sizes that would be great
thanks so much
thanks so much
