Switched out the steel wheels on my son's 2016 Sorento yesterday. It was quite the ordeal.
Seems the wheel hubs were rusting tight to the wheel hubs, making it almost impossible to remove the steel wheels.
Used some "Fluid Film" on the hubs in the fall, but it was gone this spring.
Kicking the tires did nothing, rolling the summer wheels hard at the mounted wheels worked ok on 2 of them.
One released when I put the lug nuts back on finger tight, and swerved while driving to unseat the wheel.
None of this worked on the last one. Ended up having to use a 3 lb hammer on the steel wheel near the hub, using a propane torch to heat the wheel and then hard swerves.
What is a 45 minute job turned into almost 2 hours.
In the fall the hubs - wheels and axle - will get wire wheeled and a liberal coating of this.
