What do you guys think is the best way to store a vehicle for the winter in regards to oil for roughly 5 month's without starting? I always used to change it before storage and dump in some cheap conventional oil,. and then drain it out in the spring. Should I just dump in my Pennzoil platinum and not worry about degration/moisture as it sits, and then run it in the spring? What about just pulling the drain plug and letting it drain all winter long? I hear people say that the acid in the old oil residue could form rust in the cylinders? Any help would be appreciated. -Ponch
