Hello,
What are your opinions on filling the fuel system with stabilizer vs. draining all the gas out for your classic cars and small equipment that you store over the winter?
I have read that most prefer to just add stabilizer and run it through the system then fill the tank to store as this helps keeps all the seals from drying out, but last year I noticed in my classic car in particular that the gas evaporated in the Carb and everything ended up drying out anyway. I would assume this is happening in my yard equipment too. Are there alot of deposits from evaporated stabilized gas to be concerned about and is draining everything a better option?
Anything to stop or slow down the evaporation so the stabilized gas can do its job by keeping all the seals wet? I would assume the 10% ethanol in the gas would take the place of dry gas for any water in the fuel.
Draining the gas in all of the stuff that is stored over the winter is definitely more work then just adding stabilizer but i want to make sure that I am doing the best thing so they all fire up in the spring without needing the carb and fuel system cleaned from deposits. thanks
