Nothing plugged in, mouse works fine.Are there any other devices plugged into the other USB ports?
When the keyboard goes haywire, does the computer still respond to Mouse movements and clicks?
I see you are not interested right now, but this outfit built me a real nice custom-built gaming PC 3-4 years back. A fella got on the phone with me and went down the list of options and explained each option as we went along. This option may cost a little more, but to me it was worth it. I am sure you can go to Best Buy or somewhere and get a new pre-built one cheaper. I did that first, which is the exact reason I found this AVA outfit. I sold the Best Buy PC; it was less than a year old. I am just letting you know, that's all.I realize that, I tried. I might go back to the older Win 11 OS. I'm not into a getting new PC right now, especially with all the crap that comes installed on it. I'll fool around with it later, if I get nowhere with it I might install Mint and call it a day.
If you need help with a Linux installation let me know. I think Make Use Of (MUO) just had an article about top Linux distributions. Can you go to Logitech's website to see if they have.any specific updates?I did a fresh clean install of Windows 11 on my Dell Tower. It was working fine after the install, then an issue popped up with the keyboard. The keyboard intermittently stops working, mostly in web browsers, but sometimes in other apps. Batteries are good, and trying another keyboard does not resolve the problem. The keyboard is a Logitech K520 which was never a problem. All drivers are in and there are no [!] in Device manager. Windows experts, TIA. I'd like to try and stick with this but Linux Mint is looking better all the time.
The receiver is in the back of the tower. I will check the device manager if I have problems again, I didn't do that.I've seen this happen when a couple of USB transivers are plugged into front panel USB ports next to each other. Moving one to the back normally resolved the issue. Also, check in device manager whether USB ports are allowed to cut power off as power saving feature.
Are you having any issues with updating the system? I might give it a shot checking the box on the XML file to leave it out of the installation, and then make sure it doesn't reinstall it.Getting rid of Edge and with it web view2 is the best thing I have done, those two pieces of crap are extreme resource hogs running all the time in the background.
I use a program that will not run on Linux, only Mac and Windows. There are no Linux workarounds for this program. Everything is running fine now so I will keep Linux on one PC and an old laptop, and Win 11 on my Dell tower until it will no longer work for me. When that happens I'll think about what the next step will be.I just installed kubuntu(Thanks @OVERKILL)
on a 15 year old laptop and it works fine including youtube upto 1080p.
Whats keeping windows on your old machine?
I prefer windows 11 on my main rig mostly for Gaming support.
or I'd ditch it there too.
downloaded the iso, balenaEtcher > to usb stick.
15-20min later im all done and browsing.
Might have been 10min if my usb stick wasnt a 16GB samsung from 2011.
I had a spare Intel 512GB ssd so I just swapped out the samsung 830 120GB that was in there with w7.. incase I ever want to use it as a diagnostics computer again (for old registers etc)
You could always spin up a Windows VM on Linux for that program if it's the only thing keeping you back.I use a program that will not run on Linux, only Mac and Windows. There are no Linux workarounds for this program. Everything is running fine now so I will keep Linux on one PC and an old laptop, and Win 11 on my Dell tower until it will no longer work for me. When that happens I'll think about what the next step will be.
No updating issues whatsoever. Microsoft is one of the worlds biggest scumbag companies and always was, check this out..Are you having any issues with updating the system? I might give it a shot checking the box on the XML file to leave it out of the installation, and then make sure it doesn't reinstall it.
Why can't I remove Edge from Windows 11?
Microsoft Edge is the web browser recommended by Microsoft and is the default web browser for Windows. Because Windows supports applications that rely on the web platform, our default web browser is an essential component of our operating system and can't be uninstalled.
How do I remove Edge from Windows 11 EU?
Open the Settings app, select Apps, and then click Installed Apps at the top of the right panel. Remove Microsoft Edge. Scroll down and select Microsoft Edge (Windows 10) or click the three dots on Microsoft Edge (Windows 11), click Uninstall, and follow the on-screen instructions to remove Edge from your PC.
Thanks! I might give that a try if the current install becomes problematic. It's still working fine, I removed Edge, and it is still updating w/o issue. FTR I'm not a fan of Windows or MSFT either.You could always spin up a Windows VM on Linux for that program if it's the only thing keeping you back.
Like @Rand I'm DD'ing Windows 11 for games and Office 365 apps, but everything else is on some BSD variant or Linux.
