Hello everyone, I have gained plenty of knowledge lurking for for several years periodically. I have run into one that I cannot seem to come up with a solid conclusion. I have a Lewmar Concept 1 Windless that is 17 years old. I am in the current process of rebuilding the gear box. Of course when I call Lewmar for support, they are friendly but essentially tell me the gear box is not serviceable. This is laughable, because the gear box is nothing more than a worm screw, worm wheel, 4 bearings, and 4 seals. All of the bearings and seals were available at a local bearing house. I was able to get the gear lube specs from Lewmar. It is a Omala S4 WE ISO VG 150. I only need a few ounces. The smallest I can find is 5 gals. I called Shell technical multiple times to try and find a commercially available substitute to no avail. From my reading, it looks like I need to be particular because this is a worm gear and the worm wheel is bronze.
Looking for suggestions. Thanks in advance for your help.
