The thing is that even if there is higher engine wear in the winter or normal (as in warm 70°F weather) - you'll never know that, unless you do UOA or put the engine apart and measure clearances before and after the winter. It needs particular focused study of the same oil and engine running in different seasons to find out if there any higher wear and you'll never know how much more is than in warmer weather.
In the winter there a few conditions are more common than in the summer like condense (water in the oil after it cools down). Also, the engine ECU enriches the air-fuel mixture to compensate for the colder air because colder air contains more oxygen which needs to be balanced with more fuel to stay away from leaner AFRs. Engine runs cold longer period of time until reaches optimal operating temp. (as mentioned in post #2) All those may cause more fuel in the oil which worsen its lubricating properties.
