Will a .177 pellet gun kill squirrels? Range?
So true, owls love a freshly killed squirrel. So do coy dogs, hawks and good sized ravens. I have never seen any remains of squirrels taken out and placed on the open ground stump the next day where the squirrels should have stayed if they did not want to be shot dead.
Squirrels raiding the bird feeders at yardage through the Bushnell rangefinder are consistently taken.
That's right. Practice. The excuse is.
Oh yea.....
I got 9 Grey Squirrels this Spring with a Pellet Gun. Used the Gamo Magnum's.
I saw a documentary where a groundskeeper had a very similar problem. He used plastic explosives. Give it a try and report back OP.
First, ignore the speeds posted by most air rifles. The posted speeds are shot using very light weight pellets that are not accurate at that speed, the worst at fpe delivery due to shedding speed so quickly, usually not accurate period, and are also harder than your barrel, so your rifling will slowly disappear. A pellet gun is most accurate between 800-900 fps. Find a heavier pellet that the gun shoots well and stick with it. But understand that a heavir pellet makes trajectory more pronounced. A .177 can kill a squirrel, as you only need less than 5 fpe on target.
The main problems will be, you, the gun, and then the animal. Learn to shoot the gun well, meaning get used to the trigger, the way the gun recoils (if it's a springer or a nitro piston it will recoil forward), find a scope that can handle the reverse recoil, and it clear enough and has enough magnification to clearly see your target. Then, learn the drop of the pellet you are shooting. At 800-900 fps you can have a decent MPBR(Maximum point blank range). Download chairgun, and enter information about your gun and pellets, and the software will plot your drop, and your MPBR.
Being that you have neighbors, you should try to drop them in their tracks, which will be a headshot. Make sure that you have practiced shooting acorns out to 50 feet. Body shots can leave runners or crawlers, and it's a quick way to let the neighbors know what you are doing unless they have outdoor cats.
Originally Posted By: andyd
MA state law bans leg traps. I have had limited success with live traps. And I still have to kill the thing, because I can't re-locate a wild animal. This is something I may as well make halfway sporting. 50 yds is plenty of range. Considering a multi pump or CO2 for some velocity.
You can just put the trap under water for 15 minutes.
I've killed hundreds of red squirrels with a .177 pellet gun, just your basic 800fps spring powered one. Head shots are not difficult out to 100 feet if you do your part and I usually see complete pass through shots so power is not an issue at all. If you want more power at longer ranges go to a .22 pellet gun, still widely available and has quite a bit more punch than the .177.
The spring powered rifles have been the most powerful and accurate that I have used. Never used them for squirrel hunting but I would think with headshots they would be effective. I've just always used a 22. I think squirrel is delicious. Nothing like a young gray squirrel breaded and pan fried. I don't think it tastes like chicken, it's better.
Why can't you relocate? Drive 10 miles out to the woods and let them out of the cage. I doubt they will migrate back 10 miles to their former home.
The concern isn't that they will return. The concern (real or perceived) is the introduction of a non-native species into an otherwise "clean" environment.
I have zero problems with a live trap, then a pellet pistol.
I get several each year before the apples and peaches get ripe. One year the bastages got every apple off a tree. No sympathy.
Please...10 miles doesn't constitute non-native species...and environments don't become "clean" over a few miles...what oddball criteria are you using?
If he has that many squirrels at his house, it's a pretty sure thing there are squirrels in the woods 5 or 10 miles away. I doubt his yard is the only "squirrel hotspot" where they only exist for hundreds of miles in all directions from his house.
Oz gun mags do rabbit tests regularly with air rifles, and the 17s do well with head shots all the time...not the squishy spring 17 break action you got from your uncle who got it for his 12th birthday, but a new Gamo or the like in decent condition.
The point I was trying to make is that if the OP is prohibited from releasing wild animals, the prohibition most likely applies to ANY wild animals. Not just squirrels.
I would look for a good pump...allows you to throttle velocity and, importantly, the report to suit the situation.
I have an older Crossman and 6 pumps at close range is effective and quiet, important as given our State, there is a good chance you neighbors or others may not share your enthusiasm for this solution.
I like Beeman Ramjets in .177. Good combo of weight and speed.
Sounds like a stupid law. Trap an animal from the wild, then you can't release it back to the wild 5 miles away from where you caught it ... sounds brilliant.
OP: you could just silence a .22LR and have some real fun... Im just putting it out there... a Colt AR.22lr with a 30 round magazine is just plain fun.....
Sure thing op, it will kill a lot more than a squirrel with a well placed shot. It'll mess up an elephant if you hit him in the eye. lol
I love out-hunting my friends with my open site .177 on ground squirrels. They bring out their fancy high dollar $$ high power scoped .17 center fired rifles and after one shot the ground squirrels disappear back down their holes and then you have to wait them out for who knows how long. Air rifles don't bother them and I can get off shot after shot as they sit there and stare at the end of the air gun. Even my .22 with shorts will send them in disappearing panic mode.
