Originally Posted By: DeafBrad
Originally Posted By: DBMaster
Have you added any new electronic devices in the home, including a new microwave oven? Have there been any changes to the local utilities such as new wire runs, additional cell towers, weather monitoring equipment, etc? If you current router operates only on the 2.4GHz band it might pay to get one that operates on the 5GHz band as well, assuming your devices operate on that band as well.
Hi, thanks for your suggestions. There is nothing new in the house. The set up I have now has both 2.4ghz and 5ghz. There is a Roku box on the 5ghz band. All the computers and tablets and laptops run on the 2.4ghz band. I am not sure if I am able to switch everything to the 5ghz band as that signal does not even show up on my laptop.
If you can't see the 5ghz network on the laptop, it means the wifi card in the laptop does not support the 5ghz band.
Most low end home laptops are not dual band, and most lower end android tablets are not dual band either.
All newer apple ipads are dual band, same with samsung tablets. The lower end roku is 2.4ghz only, but the new roku premier is 5ghz.
If you can see the 5ghz network, then use it by all means over the 2.4ghz.
