Originally Posted By: UncleDave
Originally Posted By: Wolf359
Airplanes don't have transmissions either. It's the start/stop nature of cars. You don't really have that as much in a boat or airplane so it doesn't really need it.
Not always- a ski boat starts and stops more than a new york taxi.
Boats are well served by transmissions, but they are extremely expensive and space consuming in the boat - pretty much a race only feature and budget these days.
The boat gets away with 1 fixed gear because of prop slippage- the prop never really operates without slippage which is the reason is can get going at all when propped for high speed running .
Actually in an airplane, the max speed of a proppeler is ruled by tip speed. Some airplanes with direct drive prop can run about 2,800 rpm for example, since if it gets to 3,000 + rpms you could get near ultrasonic speeds at the tip and the resultant shockwaves can ruin a prop tip in a no time, appart from the horrid sounds it would make and also the efficiency loss from flow disturbance. It depends on the lenght from tip to tip and its rpm. You can do the math from a 85inches diameter turning at 3.3k rpm and see what Im talking about.
