Why would BMW recommend...
PHX
...two different oil viscosities for an engine? The manual states that 5w-30 or 5w-40 is acceptable in all temperature ranges. Is this standard practice for other manufacturers too? What would you choose in this circumstance? For the record I have run QS 5w-40 euro in the past and now GC. I am curious to know why they wouldn't just recommend one.
They dont just recommend "just one" either is acceptable.
Why not be happy with options? If you look at a lot of manuals they actually recommened several weights depending on temp.
Originally Posted By: Hessen
Why would BMW recommend. two different oil viscosities for an engine?
Because there are other, more important specs of the oil than just a viscosity grade, for example, HT/HS. BMW LL oils require that the HT/HS be at least 3.5, and such value can be achieved by both Xw-40 as well as Xw-30 oils, but not just any run of the mill Xw-40 or Xw-30.
This.
Found a walmart that still carries M1 0w-40, so I bought them all. $6.27/qt.
Well they are consistent about the cold number.
Once upon a time, car manuals gave a chart listing temperature ranges for different grades of oil you could use. Seems they listed about everything from SAE 20 to 20w50.
Cool. O'Rileys near me had a promotion on M1 last month, so I picked up some 0w-40 for the Benz at $4.99/qt.
Even better.
Originally Posted By: SrDriver
Originally Posted By: Johnny
Oh those crazy Germans.
Just think where Wisconsin would be without Bratwurst & Beer.
Don't sound crazy to me!
There's always the cheese.
Originally Posted By: StrateLOSS
Trajan I was at a walmart yesterday and they had the 0w40 in 5qt jug for $21.
Are you 100% sure about that? I wasn't aware of M1 0w-40 being available in jugs, only 1qt bottles.
Likey because it's not going to make much difference either way. I would use the GC
yea Im certain of it. I only passed on it because it was SL rated...
That doesn't add up. M1 0W40 has been SM for some time now, and availability in 5L jugs would be a *new* development.
Without Bratwurst, Beer, and Cheese I would leave the state as there would be no reason to stay in "The Frozen Tundra"
Im assuring you, Mobil1 0w40 was in 5qt jugs at walmart. I had 2 jugs in my hand, reading the back and comparing it to 15w50.
and it was SL rated... This was yesterday.
Mobil 1 0W40 does have 1100ppm zinc but I think is now SM/CF and 15w50 is SM/SL. Neither is GF-4 of course. Maybe it was old stock?
