Wow, I'm almost afraid to post.
Hey Army_guy, if you plan on beating your Jeep, run a 40wt. As a fellow Jeeper, I typically run a SAE30 or 10/15W40 in my 2.5L & 4.0L Jeeps during the spring/summer/fall months. I've had some pretty good UOA results in my 2.5L Wrangler trail rig despite the beatings it sees. This is sometimes in hot temperatures, in compound low-range, spinning either 35" or 38" tires. The last time I used 10W30 under these conditions, I burnt the rings in all four cylinders. When I disassembled that engine, the main and rod bearings were in pretty decent shape. The rings, obviously, were toast. I attribute this to the instant shearing that occurred at the rings. I haven't had any issues at all running the thicker oils. Oh, the 10W40's usually sheared to a high 30wt too and I also never exceeded the factory 5500 RPM redline.
These conditions are pretty extreme, however, consider that the same engine can survive on a 10 weight oil (ask Gary Allen) in average conditions. Running a 20 weight in an old tractor engine is nothing new either. People have been doing it since the 30's. It's the conditions in which it's used. There's no doubt that today's engine management and cooling systems kick bum. They keep the coolant and oil temperature pretty stable even during the harshest conditions. This, in addition to the level of engineering built into 20wt oils, lets you have great economy while providing great protection.
So, what do the four pages of poop in this thread mean? IMO, if you beat your Jeep during the wheeling season, run a 40wt. In winter, I run 5W30. 4.0L's typically have better UOA's on 40 weights, however I've seen an excellent report a couple years ago with Havoline 10W30. If I had a daily driver which I could stop myself from lifting w/ larger tires, I would try a 30 wt and get a "feel" for what works.
I hope what I wrote makes sense. It's been a long day and I'm beat.
Happy Trails.
