Originally Posted By: Volvohead
Originally Posted By: JHZR2
Polarization or not - hasnt there always been a "standard", where hot is on one side and neutral is on the other? If so, the only risk is when something goes bad, AND the plug is wired backwards.
Not downplaying, just thinking, there is one correct side of the plug where the hot is, and everything from there should be wired consistently.
How do you know which side of an unpolarized plug is neutral, and which is hot? On the old stuff, unless you open it up and mark the plug, you just don't know. Then it literally is a coin toss whether you'll have a hot chassis if it fails.
A hot chassis on a vintage appliance or electronic instrument is a very real risk, even more so today when everything else in a modern home is now grounded. For many suppressor circuits, a failure causes a hot chassis as long as it is plugged in. If you're touching ground and touch it, you're the path to ground. GFIs are helpful, but folks don't play with an old DuMont TV or Scott tuner in the kitchen and bath. People don't think that 110 mains AC can kill, but it can (it can also badly burn).
Ideally, the neutral leg should run to the suppressor/chassis side. FWIW, when I do museum-grade restorations of vintage audio equipment, I keep the original unpolarized plug, but will mark the prong face with a small black marker dot to indicate neutral. In the rare event that a modern suppressor cap fails closed, it's only failing to neutral. But this does not guarantee safety, as the unpolarized receptacle needs to be properly wired, and the user needs to know which side of the receptacle is neutral as well.
If I know kids or the elderly will be around it, a grounded cord set goes on.
My point is that on a polarized plug, one prong is supposed to ALWAYS be hot, and the other ALWAYS neutral. In Alternating Current (AC) terms it is:
HOT-LEG (brass colored screw) and NEUTRAL (silver colored screw)
On polarized plugs 120volts, the larger prong is the neutral
The larger prong is ALWAYS on the same side of the plug.
So best practices would indicate that since black and white wires have been used in household wiring (even my knob and tube in my 1930's home is black and white at the loads), then the hot is always on one side of the plug and the neutral on the other.
So thus unless someone wires a plug backwards, one can always be assured that the hot is in one place and the neutral in the other. Then the load wires itself and its switches accordingly, and no big deal.
The only safety issue arises when someone wires a plug backwards.
