I’ve swapped an engine, done multiple timing belts, and even learned to weld, but I have never figured out how to paint.
Oh, I’ve tried, but every result has been a miserable failure. Everything I’ve painted, the coat comes off cleanly with a drag of the fingernail. I’ve used different paints, and primers.
My latest humiliation was a simple piece of scrap metal. It’s meant to hold a brake cylinder to my minibike.
I did not sand the piece because the metal is not smooth to the touch. It’s scrap that was weathered to a rough surface. All mill scale was removed using vinegar. Acetone used afterwards. You can see what the scrap looked like before I cleaned it.
I sprayed rustoleum professional primer. One coat, then waited a few minutes, then a second coat. Precisely as the instructions stated.
I waited five days later. The rustoleum sheds paint so easily with my fingernail.
. Why is painting so hard? The paint gods would tell me that I need to sand the surface, but how, oh how, oh unknowable ones are you supposed to know when you’ve sanded enough?
I don’t understand why painting has to be so hard. Is there something that can be done to foolproof painting? Some kind of device that reads the surface texture and states your surface is prepped for paint?
GAAAAAAAAAAH.
