Iowa has a decal on all E85 pumps that states it will be no lower than 70% ethanol.That is illegal.
No pump E85 is 85%, by definition E85 is 51-83% maximum. Some chains do advertise a minimum of 70% ethanol at the pump, but most are a crapshoot as to their actual percentage.If it's Truely 85% ethanol,( which it rarely is in the US) it's basically around 100-105 octane. you burn more( less energy dense), but it's far more knock resistant, and high/comp Boosted engines can make more power. in essence, it's Cheap race gas.
No pump E85 is 85%, by definition E85 is 51-83% maximum. Octane doesn’t make any power if it’s not needed to prevent detonation.
You’re not comparing apples to apples and ignored the unarguable fact that increased octane does not in itself increase power, especially when the ignition timing is not limited by the dynamic compression ratio of the engine.Nah, even crappy e85 makes more power on NA engines that are tuned and jetted to use it because it’s oxygenated allowing more fuel to burn with the same amount of air.
More btus burned per stroke is more power, that’s outside the effects of compression
Not to split hairs but it certainly is.No pump E85 is 85%.
NEX at NOB still has it and the Harris Teeter on Granby street has it. I've bought from both places a half dozen times in the last 6 months. The NEX tested E80 both times and the Harris Teeter has always been between E80 and E90. It doesn't seem to change around here for Winter, seems to be no "Winter blend" here.No longer available around here.
The NEX at Oceana used to sell it, but the pump is old, decrepit, and no longer has power. Not buying it there!
I would gladly run it. The MPG hit was 15-30%. Typical around town for the Tundra is 14MPG. E85 MPG was 10-12.
The E85 was about 60% the price of unleaded when it was for sale, so, significantly cheaper per mile for me.
The truck felt a bit more responsive on E85, but that may be placebo.
I have to worry about cold starts when up North, but not down here.
Everything about E85 was, for me, positive.
Then it doesn't meet the requirements for E85 and is falsely labeled for sale as E85. So, either Harris Teeter is selling fuel that doesn't meet specifications, or your tester is somehow incorrect. My statement about no pump E85 not being 85% is based on ASTM standards:Not to split hairs but it certainly is.
Harris Teeter here has tested E90 for me once and E83(ish) once. The other station in town who sells it (Marathon) has always tested E80 for me.
My data sample is only about half a dozen tests but I've never bought E85 from a local pump that tested lower than E80.
ASTM D5798-21 said:1.1 This specification covers the requirements for automotive fuel blends of ethanol and gasoline for use in ground vehicles equipped with ethanol fuel blend flexible-fuel spark-ignition engines. Fuel produced to this specification contains 51 % to 83 % by volume ethanol. This fuel is for use in flexible-fuel vehicles and is sometimes referred to at retail as “Ethanol Flex-Fuel.” Appendix X1 discusses the significance of the properties specified.
U.S. Department of Energy said:Fuel retailers or fleets purchasing E85 should require their fuels to meet quality standards as a condition in their supply contracts in order to help guarantee their product is ASTM-compliant.
Worth noting in the early days of e85 where it would get dumped into a vintage gas tank it was very common to have e90 as a tiny bit of water would draw the ethanol out into the pickup. As you ran the tank down past halfway your ethanol content would drop off.Then it doesn't meet the requirements for E85 and is falsely labeled for sale as E85. So, either Harris Teeter is selling fuel that doesn't meet specifications, or your tester is somehow incorrect. My statement about no pump E85 not being 85% is based on ASTM standards:
Notice it doesn't say 85%, or above that. It's a specification requirement, not a recommendation, to be between 51 & 83%. You're lucky that your local pumps have 80% content, but there's nothing requiring them to have that high of a percentage on a regular basis. Also, as a saavy consumer, you should be appropriately adjusting your price targets based on ethanol content- fuel that is consistently 80% ethanol should be priced lower than fuel containing only 60% ethanol, or else one is giving their money away to the fuel company.
https://afdc.energy.gov/fuels/ethanol-e85-specs
The Sheetz stations have a pump that is labeled "flex fuel", and everyone understands that can be anything from 51-83% because the pump says that right on it, but then there are other pumps that say "E85"...they don't say flex fuel like the Sheetz pumps do.Then it doesn't meet the requirements for E85 and is falsely labeled for sale as E85. So, either Harris Teeter is selling fuel that doesn't meet specifications, or your tester is somehow incorrect. My statement about no pump E85 not being 85% is based on ASTM standards:
I own both a flex fuel (Tundra) and a plug-in hybrid (new Volvo XC90). I don’t know what the energy future looks like, because it varies so much with administrations, but I have most of the bets covered.I've never owned a flex fuel capable vehicle nor do I know anyone with a vehicle that can use it. Now I don't even buy gas at all. Seems pointless to continue making it/selling it tbh.
Unfortunately, your old mount that guzzled JP5 like a North Carolinian on a moonshine delivery run (1950s NASCAR qualifier?I own both a flex fuel (Tundra) and a plug-in hybrid (new Volvo XC90). I don’t know what the energy future looks like, because it varies so much with administrations, but I have most of the bets covered.
I've talked to a few Subaru wrx STI owners that claim with a few mods it makes for great power and you can run additional boost.If it's Truely 85% ethanol,( which it rarely is in the US) it's basically around 100-105 octane. you burn more( less energy dense), but it's far more knock resistant, and high/comp Boosted engines can make more power. in essence, it's Cheap race gas.
When I moved to IA and got my company Chevy with the 8.1L, I assumed it was E85 and filled it up. It was winter. It would start very hard, and then lope like a top fuel dragster for a minute or so until it warmed up enough for a smooth idle. Sounded awesome.My 96 Mercury Grand Marquis loves premium fuel even though it was originally designed for regular. 263,000 miles have probably changed the engine over time and fuel is probably different than back in 96. I have found mixing as much as 50/50 E85 and regular produce a higher octane blend that my old GM loves. Noticeable power increase and no knocking on steep hill climbs that happens with regular until it downshifts. I do tend to lose around 10% fuel economy so if price is the factor I only need to beat the price by 10% which is usually easy. However in my case performance is also a factor and have been using this fuel blend for the last 150,000 miles without harm. I have noticed if I put more E85 than 50% the car begins to stutter feels like a slight misfire and pedal becomes light feeling.
The first generation Ford flex fuel cars were very hard to start in the winter but it’s worth noting that e85 pumps didn’t use to reduce ethanol content in the winter months either.When I moved to IA and got my company Chevy with the 8.1L, I assumed it was E85 and filled it up. It was winter. It would start very hard, and then lope like a top fuel dragster for a minute or so until it warmed up enough for a smooth idle. Sounded awesome.
Oddly enough it never threw a CEL, but I only ran a couple tanks before I figured out it was not E85 compatible.
