Just put a set of NGK iridium plugs in the bike. No real difference that I can see. People claiming that they last nearly twice as long, however.
John.
John.
Quote:
High Compression, boosted, NOS application like Copper Core plugs due to their larger size minimizing fine point hot spots and thus preigntion and or detonation.
Quote:
Explains a few things..AA didn't spec the Iridiums for my car, only one platinum, and the copper NGKs and the Champions it came with.. I don't have NOX, but I do have 10:1 compression.
Quote:
And it should be mentioned that there's a big difference in the quality and intended use of various platinum and/or iridium plugs. Replacing OEM longlife double platinum plugs with something like NGK Iridium IXs would actually be a step backward in quality and life potential. If you replace your serviceable OEM longlife double platinum plugs with Iridium IXs and get a performance boost, you have deficiencies in your ignition system, not the spark plugs.
Here's some additional info:
http://www.aa1car.com/library/2004/us30428.htm
Quote:
Where are you finding that Iridium plugs are a step down in quality and service life from platinums?
Quote:
He is correct, when you compare OEM double platinum plugs to aftermarket iridiums (which only are made of iridium on the one side) the service life is a lot shorter on the iridiums. I contacted NGK about the service life of their iridiums and it's only about 50k, compared to 100k for OEM platinums or OEM iridiums.
Quote:
I don't necessarily think it's really a step back in quality, in fact I've got a set of NGK TR55ix plugs sitting right here which are going into my Corvette at my next plug change. But they have a shorter service life, they definitely won't last 100k in there.
At the same time I don't think I would ever leave OEM plugs in there for 100k anyhow. In the case of my 98 Corvette, it came with the lesser quality AC Delco platinums, the ones which have the platinum "pucks" on them, and these ones always come apart. When I pulled these plugs out at 32k, all of the platinum pucks were gone! I replaced those with copper NGK plugs, and have been using them for a while, and decided to give the iridiums a try to see how they compare.
Quote:
Hey dudes.
The car is a 2002 RAV, and I am doing the plugs, The OEM spec is Iridium NGK's.
And I know a friend that will give me a set of NGK Platinums, that I can use in this engine.
My question is why the Iridium spec, I know they last longer, and that Iridium is a denser metal than plat.
But is there something else I am missing ? I called the delaer and they have no idea ?, called Toyota Canada and they told me to call the dealer, so no I am asking BITOG, group.
Quote:
And when you change the identical heat range plug of the same manufacturer from Iridium to copper core both with the same gap and one pre-ignites and detonates and one runs fine then you have some idea what I am talking about.
Yes that motor had several set of plugs trying to get the pre-ignition/detonation down and all it took copper core plugs.
In a stock engine originally equipped with Iridiums? I find that hard to believe.
