So, the logic is that since marine engines are pushed much harder than a car engine, and operated above freezing, it needs a much thicker oil for protection. But, why wouldn’t you run 25w-40 in your car engine, which is basically the same, to give it more protection?. Wouldn’t it last longer if 25w-40 gives you more protection? Isnt it really the oil flow through the journal bearings that provide the separation force? Not necessarily viscosity and pressure? If that is true, why is it better to run a super thick oil. Just because the viscosity breaks down quickly?
40 weight oil is not "much thicker" not even close.
40 weight oil in a marine engine will ensure the oil stays at or near the 40 designation and not shear down under the incredible stress and forces that a marine engine is under pushing a vehicle (boat) through water with no wheels that make something easily roll along.
Throw in the high revolutions and incredible stress and heat on the pistons transferred to the oil when the oil is sprayed onto the bottom of the pistons to help cool them down.
Comparing oil for an automobile engine and a marine engine is like comparing apples and oranges, your assuming because the fuel is the same its ok to compare but one of them has wheels that roll on a hard surface, the other is pushing a log through water.
As far as your questions above, think of it this way. Why would you assume a 25/40 gives a car engine more protection?
An automobile engine lasts far longer then a marine engine. We are talking 5000 to 10,000 rough hours, its reall y speed dependant but lets says a truck with 152,000 miles ran 4,620 hours and still going strong, a gas marine engine may last 2000 hours.
If you use lighter weight automobile oil in it, the marine engine might only last 1000 hours. Take a marine engine out in the ocean on a good hard run with lighter automobile engine oil in it, once in safe harbor slow it down to a slow idle and listen to those valves and lifters tap from the automobile engine oil unable to handle the heat. (running thin)
SO its not a question of running a 25/40 oil in an automobile to give you more protection more then it IS if you run a lighter automobile oil in a marine engine you risk seriously shortening its already much lower engine life compared to an automobile engine.
