Ha ha, Mike. Electronics are a different story. No, my point is this: most BITOGers want to use larger oil filters, which would allow more safety margin and safe length of service. A frequent topic here is what the largest filter is to fit a particular application.
But the automakers are using
smaller and smaller filters, sometimes because space is tight, but also because there still seems to be an unstated assumption that the service life of an engine is not expected to be more than about 100,000 miles. Of course, many owners don't do the recommended maintenance, which doesn't help.
So if smaller filters ultimately clog early and put the engine in constant bypass mode, with particles in the oil causing premature wear and ultimately wearing out the engine, the end still isn't likely to happen much before 100K miles. In the meantime the automakers have saved money with the smaller (cheaper) filters, and for those owners who do get the maintenance done, the dealers charge just as much for oil service using a small filter as a larger filter.
And if a customer holds onto his vehicle long enough for the engine to wear out after the warranty expires, why, the manufacturer will be more than happy to sell him/her a quality remanufactured engine. Then the cycle begins anew.
