No it doesn’t. How? Is that why anyone looking for performance wants RWD? Ferrari had AWD that disengages completely once driver shifts into 4th gear.Awd provides high speed stability.
Difference between snows and all seasons in snow can be more than 50ft and more.My all seasons stop fine in the snow. Glare ice is my only issue.
No, awd provides a touch of stability in fwd based systems at highway speed.
Yeah it'll get snows this year. I bought this car about a year ago and figured I'd just tough through the winter and see if it could do it. Now I know I need snows and I only waited because I planned to buy new wheels for the car and use the current ones for snow tires.Physics of fwd combined with a somewhat torquey turbo engine and all seasons = this. Winter tires should really help if you are in snow frequently where you live. When folks tune the MK7s for 350-400 whp I have no idea how they drive around town!
It just seems like you are paying extra for something else to go wrong.
What conditions are those? For hooning around, sure AWD is nice, but for getting around on regular roads? Its not doing much for anyone IMO.Over and over folks here refer to snow as the sole reason for getting an awd vehicle....there are so many other road conditions that average folks encounter that awd can be benefical at a slight penalty for mpgs and maintenance. The VWs call for the fluid in the Haldex clutch to be changed every ~3 years. That's the additional cost. The pump if it fails is about $150. Sure, there is more to go wrong but awd systems now are fairly common and been around long enough to have worked out the bugs.
The big one is rain/wet conditions.What conditions are those? For hooning around, sure AWD is nice, but for getting around on regular roads? Its not doing much for anyone IMO.
Compared to fwd, they've usually added some sort of PTO off the transmission which may or may not work well, an extra diff and propeller shaft, and then another pair of CV axles. It seems most of these have been engineered a bit better, but its at the 8-10 year mark where problems show up. Extra fluids to change, drag, complexity, more weight...
Sort of like dual zone climate control, why not have it, doesn't cost much extra?, but at 8-10 years you've doubled your chances of fixing it under the dash.... And if you aren't doing this stuff yourself, its another pointless $1k repair.
I'm a bit sad that now a "cheap car" is one of these tiny AWD SUV things, with turbo's and lots of extra stuff, all with parts spec'd to get most of them out of the warranty period and that's it. I suspect these will be more disposable than ever, but we'll see.
That's why I specifically limited the question to the Tiguan/Atlas, since you can get the Torque Vectoring rear axle on the RAV4 and Highlander, sort of like the Acura SH-AWD and Honda's i-VTM (on the Pilot), but they can overdrive the rear to get up to 30:70 bias.Since the new MK8 Golf R has torque vectoring rear awd diff I wonder if that has trickled to the Atlas?
So Atlas/Tig still get gen 5 Haldex I guess.That's why I specifically limited the question to the Tiguan/Atlas, since you can get the Torque Vectoring rear axle on the RAV4 and Highlander, sort of like the Acura SH-AWD and Honda's i-VTM (on the Pilot), but they can overdrive the rear to get up to 30:70 bias.
No, neither the Atlas and Tiguan has a Gen5 version of the Gen4 XWD (that was limited to GM products including Saab), even for 2024.
The GR Corolla, as available (Option on the Core and standard on Circuit and Morizo editon) Torsen LSD for the front and rear differentials.
Many of the AWD systems these days, when you take a curve hard, on power, can send some power to the rear wheels, reducing FWD plow. Even my Hybrid electric rear motor AWD does this.... so that's a benefit on regular roads.What conditions are those? For hooning around, sure AWD is nice, but for getting around on regular roads? Its not doing much for anyone IMO.
MK8 Golf R supposedly went Magna for its AWD system, including the torque vectoring rear, while the rest of the MQB platform retains Haldex Gen5.So Atlas/Tig still get gen 5 Haldex I guess.
Likely pretty complicated but you can feel it.Please explain the physics of this. I’ve gone around 170 mph in two different 2WD cars and I guarantee you adding AWD wouldn’t help.
Simple..It'll help you go, but it won't help you stop!The thread that wouldn't die - so it must be euthanised!
Somebody - h-e-l-p !!
Feel what? Ask any person on track do they want AWD or RWD, you will get 99% of time: RWD.Likely pretty complicated but you can feel it.
I certainly hope most people aren't driving their AWD vehicle that hard on the street on a regular basis... yikes!Many of the AWD systems these days, when you take a curve hard, on power, can send some power to the rear wheels, reducing FWD plow. Even my Hybrid electric rear motor AWD does this.... so that's a benefit on regular roads.
I go by: enter slow and power out. When you enter slow, you don't overwhelm the chassis and drivetrain, and get penalized with FWD plow, or RWD oversteer, or lift throttle oversteer. Oversteer is more fun, but you don't see the tree you hit.I certainly hope most people aren't driving their AWD vehicle that hard on the street on a regular basis... yikes!
Do you do track days? Autocross? Not that I'm some expert driver, but I can't say I've ever felt AWD or 4wd help reduce mid corner power on understeer, unless you have totally overwhelmed the available grip and start going into a 4 wheel drift...(the individual rear wheel torque vectoring systems aside) Sure on corner exit, like rwd, you can put down a bit more power than fwd, but that is track level driving, not road driving.
And sure you can accelerate more quickly in the wet with AWD but I don't see many people doing a 1 wheel peel at every stoplight in the rain, so most people can control their right foot a bit....
There's nothing wrong with preferring AWD, enjoy it, but for most vehicles and most people, in most situations, its doing nothing for them but providing some placebo effects and lets them accelerate normally in snow.
For my regular winter driving, I don't really care about AWD, and I've found I just prefer which one of our cars has the newer winter tires on. AWD is helping for the first 50' from a stop and then its doing nothing IMO.
But on the straight line? 2WD rules.
Been using F.W.D. over 35 years . Change to studded snows usually late October to the end of November . A.W.D. won't make a difference going downhill on a road covered with ice . Studs will .
