Who Makes Base Oils?
VA
Who are the big three (if there are three) base oil suppliers? I am assuming Pennzoil, Mobil, Quaker State, Amsoil, Red Line, Kendall, etc. all buy there base stocks from companies I have "never" heard from.
XOM makes a lot of the base oils for most of those companys.
Kendall/76/Trop Artic/motorcraft are made from CP who uses SK from Korea for synthetic base stocks, I was told they make their own conventional bases. BP/Royal Dutch Shell(SOPUS) also makes some of their own basestocks. Shell- GTL for example.
Ashland who makes Valvoline also uses XOM base oils.
Who is "SK"?
IIRC chevron makes their own and built a new plant down on the gulf coast a few years ago.
Chevron makes their own base and additives, and quite a few technologies licensed to other Cos like CP
Exxon-Mobil is the largest in the world for both base stocks and petro-chemicals (XOM Chemical).
They also co-own Infineon with SOPUS, which makes the additives/add packs.
Infineum.
Makes you wonder if both companies, XOM & SOPUS are using tri-nuclear moly in their new full syn, ie PP, PU, Mobil 1, Mobil 1 Extended Performance, Mobil 1 Advanced Fuel Economy. They said trinuclear is how many times more effective than regular moly. (50-100x better antiwear than regular moly? not sure what the exact number was now.
Maybe this is why Pennzoil conventional has such a high moly content, it could be cheaper non-trinuclear moly which is less effective and it needs that much.
I've heard Chevron and CP share a lot of technologies and have a lot of joint ventures.
Originally Posted By: CATERHAM
Petro-Canada is also a major base oil maker including high VI low PP GP III oils.
Correct. They also make great products. The unfortunate thing is that a lot of companies make "average" products but have great marketing...Petro Canada makes great products but their marketing is non-existent.
Infineum.
Sorry, I had a computer moment, Infineon is a memory chip manufacturer, LMAO!!!
