Check your radiator fan's relay. Also check/replace your radiator cooling fan thermoswitch.
Have someone test/verify that the fan unit is getting the "juice" when it hits the temperature range so that the fan should kick in. If not, most likely you have a fusible link/fuse problem (check your fuse box for master radiator fan fuse to see if it's burnt).
retest the fan and other electrical components if in doubt.
This is not as perplexing as you think (on a Japanese car that is). Try diagnosing something similar on a 91 Mustang 2.3L and you'll be into something really interesting....*grin*
