I was checking my oil yesterday and noticed a small amount of white residue under my oil cap. I'd say the film covered and area the size of a penny. From reading around here it seems this indicates moisture not being burned off properly, or that the car basically isn't warming up enough. For the time being I've ruled out a coolant issue as the car has less than 5000 miles on it and is only 5 months old. It's a 2016 nissan versa by the way. No DI or turbo or anything fancy. Although it does seem to have a sandwich plate between the oil filter and the block with coolant lines running to it.
I work 5 miles from home and it has been wickedly cold the last few days, getting as low as -27F. I've extended my route to 7 miles on a little bit faster road to try and get more heat into the car each day. And usually every other week i take it out on the highway for about 20-30 minutes to clear it out. I'm also running PPPP which was the lowest cst at 100c i could find in the 5w30 realm. My thought being that it would flow better at colder temps and maybe help it warm up a but faster?
My real question is how worried should i be about this buildup? Could this lead to shortened engine life? Is there more i can do to help fix the issue?
