The Hitrac doesn't have the 3-peak sign like the Quatrac does, if that is a consideration
Is the General AW365 available in your size?
3peak is not a requirement.The Hitrac doesn't have the 3-peak sign like the Quatrac does, if that is a consideration
I put in 2021 Kona Ultimate AWD and Tirerack offered 104 options https://www.tirerack.com/tires/TireSearchResults.jsp?tireIndex=0&autoMake=Hyundai&autoYear=2021&autoModel=Kona+AWD&autoModClar=Ultimate&width=235/&ratio=45&diameter=18&sortCode=53850&skipOver=true&minSpeedRating=H&minLoadRating=S&performance=ALLHaving to look for tires for my wife's KONA. Its AWD, and putting it through tire racks decision maker, Its giving me three choices:
Bridgestone Weatherpeak
Michelin Cross Climate
Vredestein Hitrac
Not looking at the Michelin, so that one is out. The car is not really used much in snowy weather, but rain and dry are 2nd only to noise of tire. Which one of the other two would you pick? The Bridgestone seems to get good reviews, but its a newer tire. Both are probably a bity noisier than a summer performance tire and whatnot, but anything has to be quieter than the goodyear Eagle Touring, which are the loudest tires I've ever had on a car. Other suggestions?
Run flat not an issue. But I do wonder what is different about EV tires over regular ones. If it is just noise, why not make them all quiet?
I’d be interested to know how you find them to be. They might surprise you. I was a little hesitant to buy the Yokohama g015s I have now, but have come off rather surprised with how precise they are. Their smoothness at high speed and consistency, minimal weights needed - very well-made tire.I just ordered some Yokohoma Advan Sport A/S+.... because too many tires are on back order and these will be delivered next Monday to the local tire shop. Not my brand, but with 440 utqg and shouldn't last too long. Little surprised by how heavy they are compared to various others. With my current commute, hope that they'll last 9 months to a year. Avid Ascend GT were also an option but didn't want a longer lasting tire compound.
The special "quiet EV" tires have a foam rubber liner glued to the inside of the tread. Costs extra. Consumers are cheap.Run flat not an issue. But I do wonder what is different about EV tires over regular ones. If it is just noise, why not make them all quiet?
Oh, I am, hence why I am asking here, as well.Leave yourself open for other tires at other sites.
How is the noise on these? Ride and comfort? I've had the primacy on my Tucson and quite frankly, they rode good and tracked good, but they were loud enough towards the end even the wife noticed it,. The conti LX25's I have on it now are dead quiet. No size for the KONA though, or woulda bought them again.I have a 2023 Kona N-Line AWD (Canada). The Kona is one of the best (if not the best) handling of the sub-compact SUVs. As I traded in a Ford Focus ST, I obviously valued handling. So in the end, I went with the PSAS4s. Absolutely no regrets. I have a second set of Nokian Outpost APT that I use in snow/winter and light off-roading and get much better MPGs using the PSAS4s (no surprise). As others have pointed out, everything you've heard and read about the PSAS4 and its versatility as a performance tire in wide-ranging conditions are true. I'll leave it as that.
If you value ride/comfort and longevity, then the Michelin Primacy or Defenders are excellent options.
If you need a single all-weather set to use in light-moderate winter conditions, then yes the Michelin CC2+ OR the Nokian WRG4. Here in Metro Vancouver I see equal numbers of the CC2+ and WRG4.
As good as the CC2+ is, I think you need to be prepared for a not-so insignificant it to your MPG (L/100km). When I was shopping for tires, I've found this complaint here-there. I think this is the elephant in the room re the CC2+ no one really seems to be talking about a whole lot.
