Originally Posted By: pacem
I see no connection between 'old' and losing grip. Admittedly, I probably did have summer tires on it... If there is no issue with traction and RWD, I am interested...
You're right, I should have qualified that. What I meant to say was that cars from that time in general don't have nearly as much grip as they do now. Does that make more sense?
In the dry, BMWs actually have better traction than FWD cars because they all have nearly 50/50 weight distributions, so rearward load transfer under acceleration nets more weight on the drive wheels. They have less peak traction than AWD cars, but less drivetrain loss, too.
In the snow, they have less traction on a standing start, but the fact that they are not front-heavy (unlike FWD and most AWD cars) makes all the difference in braking and seriously helps in the corners. The only place where they have an unmitigated disadvantage is climbing steep hills at very low speed, but in that case only a good AWD car will work.
Rain is somewhere in the middle. :]
As I said, 5-speed manual is important to me and I recall that BMW has a pretty smooth shifting 5-speeds.
Seems to get better reviews on carsurvey.org.
Honda's shifters are better IMO. If you didn't ask for a wagon, I'd have recommended a Civic Si.
Had a 90's 626 with V6 motor - and that was insane to maintain. Had to take apart the throttle body to replace the starter. What a nightmare. If you like DIY, not the car for you. I doubt the new ones are any different.
The Mazda 6 is all new and completely different from the 626, AFAIK. Maybe someone better informed than I can chime in.
EDIT: See post above.
Re: Audi
Does it have any advantages over BMW 5-series?
Since I want a 5-year old model, from mid 00's, how does it hold up long term? The older ones needed a lot of expensive work, I heard (But then so did the 3-series 1987 Bimmer I had)
Anyway, the feedback is not inspiring, hit and miss:
If you have an AWD Audi, it'll definitely be better in the snow than a RWD BMW; then again, an AWD BMW is just as good.
The Audi will probably be cheaper.
The driving experience is pretty different. Hard to put a finger on. You should drive both on a variety of roads and see what you like. In my experience, BMWs are typically much sharper, although Audis feel better for just meandering around town. Both are very safe and competent at speed.
Any pre-FSI non-turbo Audi will last forever mechanically; if there are problems, they will be electrical. That's why it's so hard to gauge their reliability. They seem to be much better than the older ones, though.
