I run the Castrol European formula 0W40 in my 2004 4runner (same engine as your FJ) and the oem Toyota filter 90915-YZZD3.
I found that using other than the OEM filter causes the chain rattle on start up. Mine has 250000 miles.
I don't think the oil filter will affect chain rattle. What I believe you're hearing is the oil control valve for vvt-i rattling. Sometimes if you cycle the ignition key once or twice on a cold start it eliminates the noise altogether. But yes, I have found that Toyota OEM filters rather than aftermarket filters have better results for that symptom.
Two weeks now on Castrol Edge 0w40 and it has been outstanding. Even on a -6 degree morning, the normal sluggardness and 'start-up' noises with the previous fill are gone. Engine turns over quick, easy on super cold mornings and is smooth and quiet and running great.
