which number duragloss to do step by step?
ny
i have duragloss i started with pre cleaner 265 which i did after i used a polishing compound to even out my paint. next i have duragloss 101 and 111 they dont specify but from what i can see i should start with 111 then follow with 101. any advice for these actual products listed in order would help alot thanks.
I'm sure the 101 has more cleaners in it than the 111. If you used the 101 last it would take off the 111.
My bet would be that DG would tell you to use one or the other depending on the state of your paint. Rough paint - use 101, good paint - use 111.
I have a black motorcycle and I only use the 101 on it. Since black shows literally every little imperfection, the polish in the 101 does a good job of removing the micro spider web marks I get in the clearcoat. It looks like a mirror when I'm done using it, so I see no reason to use anything else.
101 for sure first. Let it sit/cure for a day (or next week's wash), and then add 111 on top. I have never tried 111, but I've read good things. It's a pure sealant with no cleaners. I've done the 101 + 105 + AW. Looks excellent. I will always have AquaWax on the shelf. I will probably get 501 next time I need an AIO.
Yea they emailed me back 101 then 111. deff like 101 better went on and off easier and 101 showed more imporvement.
yea i have a metallic silver and it did nothing for me. I have zaino in the mail hopefully it will produce a better result. so far from what i read its one of if not the best out there.
Rating sealants/waxes as "the best" is even somewhat more difficult than oil :). You will get 100 unique opinions based on their experience.
Dont expect Zaino too give a better shine then Duragloss it's not going too happen.Zaino Z5 is without question the most disappointing sealant-polish I have ever used. Check autogeek.com for P21S products, use their cleaner and paste wax you will love the results. Also dont expect Zaino too hide swirl marks and fine scratches like it says on the bottle ,it does NOTHING too hide swirls and scratches. Dont fall for all the internet hype on Zaino.
I don't think Zaino products are hype at all. They're very good products. I just know the Zaino AIO doesn't compare to Duragloss' 101.
