Originally Posted By: The Critic
Nothing. You cannot focus on just one component of the oil, you need to focus on the entire formulation.
Agreed. The entire formulation including base oil and additives comprises a "good" or "bad" oil. Havoline was a great oil with the huge Moly doses it had, but is equally as good now with less and a much thinner base oil component.
Originally Posted By: frmtbiker
According to PQIA, Valvoline, Castrol, and Pennzoil all have less than 1 ppm of molybdenum. So what are they using for their antiwear additive?
Originally Posted By: Ben99GT
Delo 400 LE cut back on moly and added a ton of boron, more than Ultra in VOAs. It's been that way for a few years now.
I'm sure someone here who has more chemistry knowledge than I could address the combination of base oil with Calcium, Phosphorus and Zinc for antiwear, but Pennzoil has been upping their content of Boron and Nitrogen (instead of Moly) in their recent oils and showing great results. I believe someone on this board mentioned that Boron works similarly to Moly in it's antiwear capabilities especially in aluminum block engines, and provides better cleaning properties as well. Moly has become very expensive in the last few years, so we have seen a trend of many oil manufacturers moving away from it, and finding other combinations that work as well or better.
Originally Posted By: biodiesel
That's a really cool website and informative chart. Kind of bummed to see Pennzoil without any Moly but the Formula Shell has quite a bit. May have to switch from PYB to Formula at the next OCI and see how it does.
The Formula Shell and PYB UOA's on this board recently have both turned in great results, so IMO you may be splitting hairs for no reason. Right now just about any SOPUS product seems to be doing very well, including QS and the full line of synthetics. Of course, that could be subject to change if they become more profit driven over the quality of what they currently produce, in the future. I don't have anything but personal preference, but if you are using PYB now, I'd stick with it as it is one of the favored dino's on this site due to great wear numbers. Also the new GF-5 formulation is just hitting shelves and looks to be even better.
