quote:Any cheapo 10W30 oil with a bottle of GM EOS for the initial start and cam run in. And just to be on the safe side don't start with the synthetics until after 3000 miles have passed. The Rotella 5W40 seems to be a good oil at a good price.
Originally posted by Oilua: Just overhauled my toyota 22re.What weight and brand oil should be recommended.Also after a thousand miles and after 3000 miles.When can I put synthetic grade oil and which weight.I am running Napa gold filter.
quote:So then something like Redline should work perfectly, but yet Redline doesn't recommend that you use their oil until you've broken in the engine.
Originally posted by Ken2: If you can get Schaeffer's or other oil with a very high moly content, that's an excellent way to go. Break-in is the high points of the moving parts rubbing against each other. They can weld together then rip apart and be carried off in the oil. This leaves micro-tears in the underlying metal and allows increased rates of wear. An oil with a very high antiwear capability allows these high points to press against each other and flatten instead of being torn off. Without the micro-tears in the metal, future wear is decreased.
quote:I agree, a pint of GM EOS part #1052367 is a very good idea regardless of which oil you choose. I also thought this was interesting BI-20 BREAK IN OIL [ June 13, 2004, 07:42 PM: Message edited by: 69 Riv GS ]
quote:What should it be? is there a spec that it would call for anything other than the original... if 5w-30 then so be it if 10w-30 then so be it. As for the miles, I would say a few thousand before Syn and make sure no oil burning then change. --- What I recently did on a 2004 TACO was FF til 1899 miles Dealer oil (citco) 5w-30 to 2999 miles Mobil New Car Formula 5w-30 to 4429 Miles PenZoil 5w-30 SUV till 6319 Miles (on 6-12-2004). FF gave the best MPG.
quote:ABSOLUTLY NOT!!!! Not until after break in.
Originally posted by Steve S: The best choice would be a heavy duty engine oil ,Rotella ,Delo 400 etc.
quote:I`m probably full of sh*t, I figured ZDDP was a friction modifier. Anyway, it is absolutly imposable to hone a cylinder as smooth as the manufactures do, therefore you need a different breakin procedure with a rebuild. A new engine cylinder is almost shiny from the factory, and believe it or not, they are assembled with very little oil around the ring packs and they break in very quickly. That`s why they can come from the factory with synthetics allready in them.
Originally posted by sbc350gearhead: I thought most HDEO's didn't have any FM's?![]()
