Which 75W80 GL5 manual transmission oil?
Switzerland
Hi,
my gearbox calls for a 75W80 GL5 oil with non corrosive EP additive as it has brass synchronizer rings. I actually have TransElf TRJ 75W80 oil which is a synthetic blend lubricant with excellent cold weather viscosity carateristics (47 cSt at 40°C). However this lubricant has only a viscosity of 8.5 cSt at 100°C and I fear this may be too thin for my gearbox as most 75W80 oils are around 10 cSt at 100°C.
Do you think 8.5 cSt can be a problem in a manual transmission (premature wear)?
Do you have recommendation for a good european available (possibly full synthetic) 75W80 GL5 transmission oil for use in a synchromesh transmission? (Redline products are not applicable in my case as their GL5 are not suited for synchromesh transmissions and MTL, MT90 are GL4).
Thanks
Mine is a Volvo S40 with engine and transmission that are available only in Europe (atmospheric 2.0 140hp). The gearbox is built by Renault (French manufacturers). In Europe, a lot of manufacturers such as Renault, Citroen, Peugeot, Fiat, Alfa Romeo?...call for 75W80 GL5 oils.
Kilou, just happened to come across this.
No specs, as such.
Motul HD GEAR 75W-80
A high viscosity lubricant, HD GEAR is specifically developed for manual transmissions and hypoid rear axles with extreme loads. Resistant to high temperatures, HD GEAR features anti-wear, anti-corrosion and anti-foam properties. Suitable for Peugeot and Citroen manual gearboxes.
SPECIFICATIONS
Product HD GEAR 75W-80
Feature High lubricating ability. Performs well with extreme pressure. Suitable for Peugeot and Citroen manual gearboxes.
SAE/DOT Standard 75W-80
Specification API GL4/GL5 & MIL-L-2105D
Manufactuer's Approval -
Compatibility All gearboxes without wet clutches & hypoid rear axles without LSD.
