Where is the PCV located on a 2006 Maxima?!
Detroit, Michigan
I just purchased a new PCV for my 2006 Maxima. Looking over the engine reveals that the PCV is no where in sight. I am guessing that it may be located under the #4 coil?
Anyone else change one of these out?
I would appreciate any tips starting with the location.
Thanks ~ Radman
should be connected to the air filter housing somewhere. Or it might go from the valve cover to the throttle plate. Just look in those two places. Thats the most common.
On my 2002 Maxima (VQ35DE) the PCV was on the back corner of the engine (passenger side). Was a 22MM I believe (or can use even channelocks as it is not that tight)
