It really comes down to one's comfort level. If they want to dump the FF at 1000 miles, who really does it bother? I have always been a fan of not only dumping FF on the motor early on, but the entire drive train on all my vehicles. All drive train fluids changed within 3000 miles. It is my comfort level. If someone wants to do all their OCI's at 1000 miles, no big deal. Heck, change the oil weekly if it helps you sleep better at night. Not everyone is interested or has the comfort level to go as far as is possible on oil and lube changes. While I do dump FF early on, I generally have no problem going out to the OLM or manufacturer recommend intervals, and sometime even longer depending on the vehicle in question.
And if you saw the magnetic drain plug from both my 2013 1500 Silverado and 2015 2500HD Silverado pickups at 3000 miles, you would understand my wanting to do it early. Both plugs had so many wear particles on the plugs that it was if someone had stuck my cat's tail in a light socket. The 1500 rear diff was over 1 quart low on the FF, and the 2500HD rear diff was 2 quarts low on FF. Front diff on the 2500 was below minimum recommended level. So given this anecdotal experience, I will always dump FF on everything within the first 3000 miles at most. Motors will always get an oil change before 2000 miles.
