I have a six-speed with a mix of brass and carbon-coated synchros, with helical-gear limited slip. Specialty Formulations' MTL-P is spec'd at 75W85, recommended for Honda transmissions.
This car is driven daily (a touch over 20,000 miles per year), seeing moderate amounts of aggressive driving and WOT. I've lightly grinded gears at least twenty times since putting in the MTL-P (terrible, I know). Transmission shifts just as beautifully since the day I put it in, except after overnight cold soak.
So I've been using it for about 24,000 miles (extremely pleased), and I'm wondering how much longer it can go before draining. I will do a used oil analysis when I do, but I refuse to sample it without draining it. This is because I don't want to pay for two used oil analysis (once mid-interval and once at draining) since Terry's services are a little expensive. Also, not having a used oil analysis done at draining is not an option; I'm way too OCD to accept such a proposal. Thus, I would like some opinions on a safe mileage at which to drain/sample. A balance, if you will, between wasting fluid by changing out too early and damaging my transmission from waiting too long.
Knowledgeable responses with relevant data are preferred. But internet oil-master wannabes with brash, unsupported generalizations are welcome as well.
