The newest problem with my truck this week is, the a/c compressor coil got so hot it burned up and melted! It also took out the a/c pulley and the a/c clutch. I have the new parts, but am waiting on some shims and snap rings.
In pics 1 & 2 you can see the melted coil protruding from behind the pulley. The next pic is one of the pulley magnetic rings? that fell off the pulley face. The last 2 are of the clutch, the rubber melted on the front side of the clutch, the other is burnt debris inside of the clutch.
Thank God I keep old parts. I put my old clutch back on so the serpentine belt could turn all of the pulleys.
If it weren't for bad luck, I would have no luck at all.
