Originally Posted By: 1993_VG30E_GXE
Basically Buick, to do the initial fill after my overhaul, should I just put in the amount in the service manual WITH oil filter change?
My dipstick is wonky, it looks like it's not fully seating at the bottom so I don't trust it. And after that, should I just stick with the Service Manual amount and refill it with that.
Like when I drain the oil later, how much would you suspect is still trapped in the engine after I remove the used filter.
Back when I ran the preluber on the GN, I would drain it until oil stopped coming out of the pan and then hit the preluber which would purge the oil system of oil. I got a good 1-1.5 quarts more out of it but this was including the volume of the oil cooler and lines. I would say at least half a quart is sitting in the engine be it in the heads, oil galleys, crankshaft, etc.
The factory recommended capacity with filter change is a safe bet after the first fill.
I would use an extra 1/2 quart for the first fill.
