When did multi viscosity oils come out?
Apple Valley, California
I found an owners manual for my tractor. Its either a 1956 or or 1957 year model. I'm not 100% sure but 56 was the first model year and in 58 the head lights were in a different place.
Anyway it calls for 10w30 oil in the engine and hydraulics. I would have guessed a straight 30 in 56-57.
Guess I goofed with sae30 in the hydraulics and 15w40 in the engine?
AFAIK, 1954 was the first year for a 10w30 multi-viscosity oil. I think Kendall lays claim to producing the first one then.
Another early one was Royal Triton 10w30, the purple-dyed oil.
And that was one of the best in its day.
Found it right here on BITOG
https://bobistheoilguy.com/forums/ubbthreads.php/topics/2792107/Re:_Oil_history:_When_was_10W4
I'm not totally sure of my facts but here in the UK, I believe the first multigrade to launch was Duckhams Q 20W50. This was the original oil for the Mini, where the same oil was shared by both the engine & gearbox. I'm happy to be corrected if someone knows better.
Anyone else have a 1950s owner's manual? Mine for 1962 Chevrolet recommends SAE 20 or 10w30, which was already old news by then.
The 15w- 40 will be fine . the tractor will tell you if the 30 oil is too thick. 30 is good to freezing.
You didn't goof at all. It'll work very well on that grade, as the 15w part is OK in CA, and the "40" part just means slightly thicker oil films where hydrodynamic, and it will use probably 1% more fuel due to the thicker oil. That is it, no other issues.
You asked "When did 10w30 come out?" 1953, and both Kendall and Amalie oil companies claim to be the first to have it that year.
I was surprised to see 5W20 shown on the viscosity chart in the FSM for my '57 Plymouth.
This just proves that:
a) OM's are overrated and no one reads them ... like IKEA instructions
b) Thicker oil is better.
My most recent OM is 2 years old and it's on my list of things to read! Meanwhile I am violating it already by not using 0W-20
That is surprising, so the "thick vs thin" debates probably also started back then too.
