- Joined
- Sep 1, 2024
- Messages
- 1,159
This burst test blew the gasket. As it shows the filter moves away from the thread making it worse for the gasket to seal.
More like 300-400 microns, or more.Leaf spring gaps shown in many threads is way more than 10 microns.
It is when you don't expect more than 12 PSI across your filter element (where you set the bypass valve).60 PSI of oil pressure isn't what I'd call "high pressure".
I was there. I was driving a "Dodge" Challenger with the 2.6L engine.Unless there was a serious flaw (including possible flaws in the oil pump pressure relief design & operation), no filter it going to "burst" at 60 PSI. Seems like an old internet story without some proof of the claims.
There's a difference between the pressure inside the can, verses the dP across the media. You could have 300 PSI in the can, and only 12 PSI dP across the filter bypass valve).It is when you don't expect more than 12 PSI across your filter element (where you set the bypass valve).
Sure the filter wasn't double gasketed? Stories can still get on the internet later down the line, lol.I was there. I was driving a "Dodge" Challenger with the 2.6L engine.
Is not an "internet story" because the internet didn't exist back then.
Yes, thanks for making my point.There's a difference between the pressure inside the can, verses the dP across the media. You could have 300 PSI in the can, and only 12 PSI dP across the filter bypass valve).
Absolutely certain Fram started marking an updated filter P/N as being safe for the Mitsubishi high pressure. Was black text just above the rolled seam. Even Mopar's filters were so marked.Sure the filter wasn't double gasketed? Stories can still get on the internet later down the line, lol.
What point? You don't seem to understand the difference between the oil pressure produced my the pump inside an oil filter, and the delta pressure across the media produced by the oil flow & viscosity. Did you watch the video in post 21?Yes, thanks for making my point.
What was the "full oil pressure" of that 2.6L engine?3rd party oil filter manufacturers only expect the pressure across the filter element to be borne by the enclosure. For the 1978-ish Mitsubishi 2.6L the enclosure was at full oil pump pressure.
You are not listening in how I fully understand the difference.What point? You don't seem to understand the difference between the oil pressure produced my the pump inside an oil filter, and the delta pressure across the media produced by the oil flow & viscosity. Did you watch the video in post 21?
How many times have I said "60 PSI"?What was the "full oil pressure" of that 2.6L engine?
Back in the early 2000s I worked as a lube "tech" for Sears.Filters bursting with only 60 PSI of oil pressure in them seems a bit of a stretch. Where the cans thin as tinfoil.
Per your post 23 (read it again), I don't think you do understand the difference. Otherwise, post 23 needs clarification.You are not listening in how I fully understand the difference.
Of course the oil pressure is highest at the pump outlet. And the oil pressure sensor will be located somewhere close to the down stream of the filter ... so what you see on the dash gauge is basically what the pressure is inside the filter.You don't seem to understand if full pump pressure is delivered to the filter then bled off for bearings, cylinder jets, etc, and that is where the oil pressure gauge is installed, that the pressure between oil and the outside world is the full pump pressure.
There is some pressure drop across the filter element. But there is a great pressure drop feeding the bearings.
Like said, 60 PSI is not "high pressure".How many times have I said "60 PSI"?
Did you hear if any of them "burst" in use? Most oil filters today are still pretty thin, and can also get damaged if not installed correctly. Been here a long time, and never seen anyone ever report their filter "bursting". Slightly leaking, yes ... "bursting", never. Only instances close to a "bursting" filter is if someone double-gasketed it (ie, left the old stuck base gasket on the filter mount).Back in the early 2000s I worked as a lube "tech" for Sears.
The oil filters they used were hardly thicker than beer cans. Had to be careful screwing them on to not crush them.
No idea who made them for Sears.
They were plain white with nothing but a number that would pull up in the computer system we used (green screen DOS program).
That is wild... would be awesome to see a member do a cut open on one of these here...I already searched on on ebay. Found some white can ones, but they are not plain white. One of them is already dented though! lol
I’d love to cut them open and post them for you. PM me if interested.That is wild... would be awesome to see a member do a cut open on one of these here...I already searched on on ebay. Found some white can ones, but they are not plain white. One of them is already dented though! lol
