when change brake fluid?
Originally Posted By: Volvo_ST1
My car is 16 years old with a bit over 200k miles on it. I have rebuilt the front calipers twice, the rear calipers once (then replaced them) so far. I have replaced all brake hoses once. Fluid gets replaced every 12 to 18 months.
In a harsh climate I would rebuild the calipers more frequently. I see no reason why a well-maintained caliper can't last pretty much indefinitely. If the piston seal wears too much, scuffing of the caliper cylinder may occur. Then the caliper may need replacing. That's why I would not go more than 5 years or 100k miles without rebuilding the calipers. One front caliper for my cars costs over $300. The rear caliper is a bit less costly. A rebuild kit costs about $14 per caliper. You do the math.
As a datapoint:
I have a 1998 BMW 528 which is "daily driven" in the Toronto area with very salty winters. Last fall I was doing the rear brakes and ordered a caliper rebuild kit since I figured it couldn't hurt. It's nice to have it done and all, but it was unnecessary. There were no signs of leaks or any rubber boot or seal degradation. I believe the OES of these calipers to be ATE. My fronts have never been rebuilt. The calipers all around are fully operational and rust-free. Fluid change target is once per year, but sometimes it's two. My usual fluid of choice is ATE Type200/SuperBlue DOT4 (alternating).
Why would someone need to rebuild their caliper every 5-10 years if the rubber is fresh and the metal is not rusted? I can understand if the car is in harsh environment (salt road) but it is not like this everywhere.
Sometimes a caliper that looks fine becomes sticky.
Other times, the caliper uses a Phenelic piston instead of a metal one, and that piston then tends to expand and not operate as smoothly, and sometimes it is impossible to push the piston back in when making brake repairs.
Anyway, here in Florida, I don't see calipers fail in less than 10 years, unless the brakes have been neglected so much that the piston gets over-extended.
Cars that come here from places with road salt are a completely different story.
THANK YOU one and all! found a new, great mechanic yesterday. he did brake bleed, replaced system with new brake fluid, and steering fluid. yay! now my Caddy has new Mobil 1 oil and filter, engine air filter, cabin filter, transmission fluid and filter, radiatorfluid.
i helped detail it in/out, used clay bar on the paint, with collinite wax to finish.
hope to keep this one a long time! could not have done it without you guys!~
THANK you
best
bob
