OVERKILL
$100 Site Donor 2021
Originally Posted By: dailydriver
Originally Posted By: kc8adu
while it is made with continuous grids they have several connecting points on each that all line up once the plate pair is wound.those get cast together as part of an interconnect or post.
the big killer is water loss that accelerates corrosion.this takes out an interconnect.
remember the acid becomes more concentrated as you lose water.i get these types of battery often that are testing poorly but have an unusually high oc voltage at rest after being fully charged.i carefully add small amounts of water and let it soak in.then do an impedance test.if still poor i give each cell another dose of water.if its still not improving its just worn out.most improve a lot.many like new.
Originally Posted By: SHOZ
The spiral cells have one major drawback. There is only one grid per cell. It that breaks loose at the internal busbar, or internally in the wrapped cell the battery goes OC.
HOW do you get the water in there, through the dense sponge covered vents in the top???
Was wondering the same thing!
