Originally Posted by KJM
Hi RayC
My new 2018 mazda3 touring trim has 7x18 tires. I too want a second set of rims for winter tires. I too want to stay as close as possible to factory parts.
Unlike you, I want the winter tires to be on smaller mazda supplied 16" rims, with mazda logo center caps.
Everything I read says smaller rims make most sense for winter tires. I am doing all i can to make sure I can put same rim on my 2018 mazda3 touring trim as comes standard on sport trim.
I just wish I could find someone that has done it.
The best price was
https://www.mazdabestpartsonline.com/oem-parts/mazda-16-quot-wheel-alloy-9965d06560.
This website indicates the 16" rims fit the Mazda3 touring trim model.
When I called their parts guy tried use my VIN number, like bdcardinal posting said. That led to inconclusive results, since I am making a change to the car.
16" Wheel, Alloy - Mazda (9965-D0-6560) rim size is consistent with bdcardinal posting Mazda Global Electronic Parts Catalog. 16 rims are standard on the 2018 mazda sport trim comes with 16" rims. I
I called another mazda dealer with competitive pricing
https://parts.mazdaofwooster.com. The parts guy their sounded like he knew what he was talking about. He thought what i was trying to do made sense and these mazda 16" rims ought work
When I bought the car I asked a dealer mechanic if I could put 16" rims on he said "yes, only issue might be speedometer may not be 100% accurate.
This concerned me, but by installing 205/60R16 tires I would have tire with much larger sidewall making the overall tire diameter the same as the 18" rims.
I called Tire Rack, they did not think this would be much of an issue with 16" rims. He said its safe to assume I can use same size as car's base model (in this case the madza3 sport trim.)
https://m.roadkillcustoms.com/tire-change-speedometer-change-calculator/ indicated the speedometer change would be negligible.
(Another issue I was concerned about was the tire pressure monitoring. This is a non issue since there are no pressure sensors in 2018 mazda3. It uses indirect method).
Still I just wish I could find someone that has done it, or is considering doing the same.
- KJM
And now you know why I'm sticking to rims that are same size as current equipment. I went up & down the same issues as you don't feel like taking guesses when spending about $1500. My winter season is very short and even if 18" wheels with winter tires are not optimal, I'm guessing they are still better than all-season tires.
Ray
