This thread could be BITOG 20 YEAR at least top 50 material. Let's see where it goes. Not so much that the POS broke but at least 1 person thinks there was some level of PM on the truck.
just for kicks and giggles are there pads and rotors on the other three corners?
if there aren't....
also i might check to see if the lugs on the other wheels are missing or finger tight?
The truck is a rolling disaster and you’re lucky there wasn’t serious injury or property damage from it coming apart on you.
The owner seems obsessed with the axle theory, but that could just be your way of relating the facts as you see them. Either way, he...wait, you said he came and got the truck from the side of the road. So he had seen it and inspected it. If he is still adamant the axle broke or otherwise failed, he’s up to something or just plain ignorant.
You should be very wary of all future dealings with this person. He does NOT have your best interests in mind, that is clear.
The towing piece went fine, it's the return trip that disintegrated. I totally get this:
Even if the internals of the axle was exploded, that could not explain how a wheel would fly off.
That assumption was clearly wrong.
From the looks of the remaining studs, four of those lug nuts were loose or missing. The single, remaining, tightened stud broke, and off came the wheel. Rotor, too.
Exactly. I doubt anyone does by the way.What do you mean by PM, preventative maintenance?
the axle theory, could it be it just wore out and just happened to coincide with me using it? It does have north of 200K. Probably original judging by the rest of it.
I was running empty at the time of the accident and had been for at least 100 miles. More like 120.
You know, correlation is not causation type thing.
There are no finances at stake here, just ego. He maintains his version, I do mine. Nobody is suing anybody. We don't have the grounds for it.
The cost of their services will likely be higher than the entire vehicle is worth. It's fine.
Anyway, I conversed with him again today, he told me the loose lug nuts theory is BS, and that I broke the axle by overloading. And that the other wheel is crooked, so it's the differential cover he wants to take off and show me.
I suppose the axle is broken, or seized. The only real question is, what came first, the loose wheel and then the axle snapped / seized or vice-versa.
Or maybe the diff fluid leaked out, and it got locked up, I don't know.
Seems to me if the wheel came off, the rest of the system could not bear the weight of the trailer, even empty and snapped the axle/differential? The right rear wheel, the one that's there is at an angle, it's not straight. You will just have to take my word for it.
