All of these front wheel drive vehicles now seem to use a wheel bearing hub assembly. It seems to me they just do not last like the old style bearings that would go forever if greased when you changed the brake pads.
I have read that the manufacturers went with the hub assembly units because they are faster to install and less chance for someone on the assembly line to screw the bearings up by not adjusting them properly.
I just changed another front hub assembly out today on a Chevy Venture minivan and wondered how critical is the final torque of the big axle nut. I torqued it down to around 150lbs. but read the factory manual after the job was done and it called for 118lbs. (sort of like ready, fire, and aim)
I may go back and loosen it a bit trying to get closer to the 118lbs. This makes me wonder if one reason these bearing hub units don't last is because people are over tightening them (which reduces the lube film) and may contribute to early bearing failure.
I have searched Google about this subject but there really isn't much information out there. Does over tightening that big axle nut increase the load on the bearing and could be the cause of early bearing noise/failure ?
