Proper torque is critical on the hub nut.
I have read that several times. My torque wrench is a pretty inexpensive made in China unit with a 10 ft-lb to 150 ft-lb range. I have had it for less than one year, used it only a handful of times, don't let it get knocked around, and store it on its lowest setting. Should that be good enough for dialing in the correct torque?
Also, the FSM says to use new bolts and driveshaft nut upon install. The driveshaft nut should be no problem, but where can I get the bearing/hub assembly bolts? They will not come with the new unit and I cannot find them listed anywhere.
