- Joined
- Sep 28, 2002
- Messages
- 39,799
The steering wheel should just be off center. There should be no pull if that's the only axis altered.
Side to side toe is a relatively new indication. Most vehicles just had so much static toe in (RWD) or near ZERO toe (fwd).
side note: Someone posted it here. The Crown Vic had static tow OUT. The only way I can see that working is if the scrub radius was way outboard. Even then, I'm not sure if it works in my head.
