Well got curious...Castrol's Product Data Sheet says Syntec 5w50 has low temp cranking visc(cpMax) of 6600 at
-30...guess what the 5w30 spec sheet says...????????????
6600 at -30...both specs are degrees C...However...Low temp pumping visc is 40000 for 5w30 at -35...6000 for 5w50 at -35..
By the way 5w40 and 5w50 specs for above are the same...
I could think of worse oil and weights to be running...but I also could think of better...INTRODUCE YOUR FRIEND TO BITOG!
